Shipping will be calculated and coordinated with an AEROEX Representative after the purchase of this product.
Mist-Fit MF-560 Mist Collector
Mist-Fit MF-560 stands out with its compact design and high-performance fiber bed filtration, offering superior air purification at a competitive price. Ideal for high-pressure coolant and oil applications, it ensures efficient oil drainage back to the CNC machine. The 20" x 20" footprint allows easy machine mounting, effectively eliminating mist, smoke, and fine particles. Its modular design supports additional customization, featuring a direct mount for a streamlined setup.
Engineered for Swiss lathes and other high-demand applications, the MF-560 excels in environments requiring advanced coolant, oil, and smoke management.
Technical Data:
- Coolant Filtration (Standard)
- Oil Filtration (Optional)
- Air Flow: 500-600 cfm
- Machine Tool Enclosure: Up to 250 ft³
- Motor: 0.75 hp
- Voltage (Amps):
- 220/1/60 (2.5)
- 230/3/60 (1.57)
- 460/3/60 (0.95)
- Temperature (Max) pH Limits: 125°F / 50°C, 5.8-9.8
- Weight: 96 lbs / 122 lbs with HEPA filter
- Dimensions: 20" x 20" x 28" (base unit), additional height with HEPA filters
- Inlet Connection: 6" ø
- Sound Level: 66 dB(A)
- Optional 4th Stage Filters: HEPA filter 95% @ 0.3 μm and 99.9% @ 0.3 μm
Country of Origin: Canada
Separation Stages
Multi-stage separation process effectively eliminates a wide range of airborne contaminants, ensuring not only the longevity and efficiency of machinery but also promoting a healthier workplace environment. By reducing exposure to harmful particulates, it enhances air quality and safety for all workspace occupants.
The innovative 1st stage Mechanical Element separates up to 90% of the oil mist and swarf, with smooth metal surfaces for quick fluid drainage back to the sump.
The 2nd stage Demister Element supports the 1st stage to ensure up to 95% of the mist and swarf are removed with washable filters.
The 3rd stage Fiber Bed mist filter is depth loading and captures small mist particles. With a filter rating of MERV 15, it can be used without a HEPA filter on most applications, with a typical life of 1-3 years.
HEPA Filter captures sub-micron mist, smoke, and bacteria. Efficiency is 95% @ 0.3 μm as standard, and optional 99.9% @ 0.3 μm, with a typical life of 2-4 years.
Pre-Filter Box is recommended for oil and heavy mist, extending filter life, particularly for Swiss screw machines.
Installs Quickly
Easy to Use
Clear the Air
Revolution is in the Air
Why Choose AEROEX?
Premium Filtration
Affordable & Efficient
Health & Safety
Environmental Excellence
Custom Solutions & Expert Support
MF 550
- Max Enclosure: 250ft
- Motor: 0.75hp
- Max Temp: 125°F (50°C)
- pH Limits: 5.8-9.8
- Weight: 65lbs (HEPA +10lbs)
- Dimensions: 15" x 15" x 26"
MF 560
- Motor: 0.75hp
- Weight: 96lbs (HEPA +26lbs)
MF 1050
- Air Flow: 900-1100 cfm
- Max Enclosure: 450ft
- Motor: 1.5hp
- Weight: 98lbs (HEPA +26lbs)
- Inlet Connection: 8" ø
- Sound Level: 68 dB(A)
MF 1950
- Air Flow: 1900-2000 cfm
- Max Enclosure: 2000ft
- Motor: 3 hp
- Weight: 270lbs (HEPA +54lbs)
- Dimensions: 25" x 25" x 36"
- Inlet Connection: 12" ø
- Sound Level: 72 dB(A)
Machine Tool Enclosure Sizing Guide
When determining the sizing of mist collectors, several factors come into play. As a rule of thumb, we suggest multiplying the machine enclosure volume by a factor of 2-6 depending on the mist level, with a factor of 2 suitable for large machines of 1000 cubic feet and above.
Condition | Multiplier (X) | Formula |
Light Mist | 1 to 2 | L x W x H x Multiplier = Required CFM |
Moderate Mist | 3 to 4 | L x W x H x Multiplier = Required CFM |
Heavy Mist / Smoke | 4 to 6 | L x W x H x Multiplier = Required CFM |
Example: On a lathe with high-pressure coolant and an internal dimension of 5ft high X 6ft deep X 10ft long, the machine enclosure is 300 cubic feet—the calculation suggests an airflow requirement of approximately 900 CFM, when multiplied by a factor of 3.
Play Now
