Shipping will be calculated and coordinated with an AEROEX Representative after the purchase of this product.
Mist-Fit MF-1050 Mist Collector
Introducing the high-performance Mist-Fit 1050, a compact mist collector that leverages fiber bed filter technology for unparalleled air purification. Designed for high-pressure coolant and oil applications, this system efficiently returns oil to the CNC machine while maintaining a compact footprint for easy installation. Its modular design accommodates additional features as needed, ensuring a tailored solution for your workspace.
Technical Data:
- Coolant Filtration (Standard)
- Oil Filtration (Optional)
- Air Flow: 900-1100 cfm
- Machine Tool Enclosure: Up to 450 ft³
- Motor: 1.5 hp
- Voltage (Amps):
- 230/3/60 (2.7)
- 460/3/60 (1.6)
- Temperature (max) pH Limits: 125°F / 50°C, 5.8-9.8
- Weight: 98 lbs / 124 lbs with HEPA filter
- Dimensions: 20" x 20"
- Height:
- 28" base unit
- 33" with 95% HEPA filter
- 41" with 99.9% HEPA filter
- Inlet Connection: 8" ø
- Sound: 68 dB(A)
- Optional 4th Stage Filters:
- HEPA filter 95% @ 0.3 μm
- HEPA filter 99.9% @ 0.3 μm
Country of Origin: Canada
Separation Stages
Multi-stage separation process effectively eliminates a wide range of airborne contaminants, ensuring not only the longevity and efficiency of machinery but also promoting a healthier workplace environment. By reducing exposure to harmful particulates, it enhances air quality and safety for all workspace occupants.
The innovative 1st stage Mechanical Element separates up to 90% of the oil mist and swarf, with smooth metal surfaces for quick fluid drainage back to the sump.
The 2nd stage Demister Element supports the 1st stage to ensure up to 95% of the mist and swarf are removed with washable filters.
The 3rd stage Fiber Bed mist filter is depth loading and captures small mist particles. With a filter rating of MERV 15, it can be used without a HEPA filter on most applications, with a typical life of 1-3 years.
HEPA Filter captures sub-micron mist, smoke, and bacteria. Efficiency is 95% @ 0.3 μm as standard, and optional 99.9% @ 0.3 μm, with a typical life of 2-4 years.
Pre-Filter Box is recommended for oil and heavy mist, extending filter life, particularly for Swiss screw machines.
Installs Quickly
Easy to Use
Clear the Air
Revolution is in the Air
Why Choose AEROEX?
Premium Filtration
Affordable & Efficient
Health & Safety
Environmental Excellence
Custom Solutions & Expert Support
MF 550
- Air Flow: 500-600 cfm
- Max Enclosure: 250ft
- Motor: 0.75hp
- Max Temp: 125°F (50°C)
- pH Limits: 5.8-9.8
- Weight: 65lbs (HEPA +10lbs)
- Dimensions: 15" x 15" x 26"
- Inlet Connection: 6" ø
- Sound Level: 66 dB(A)
MF 560
- Motor: 0.75hp
- Weight: 96lbs (HEPA +26lbs)
- Dimensions: 20" x 20" x 28"
MF 1050
- Max Enclosure: 450ft
- Motor: 1.5hp
- Weight: 98lbs (HEPA +26lbs)
- Sound Level: 68 dB(A)
MF 1950
- Air Flow: 1900-2000 cfm
- Max Enclosure: 2000ft
- Motor: 3 hp
- Weight: 270lbs (HEPA +54lbs)
- Dimensions: 25" x 25" x 36"
- Inlet Connection: 12" ø
- Sound Level: 72 dB(A)
Machine Tool Enclosure Sizing Guide
When determining the sizing of mist collectors, several factors come into play. As a rule of thumb, we suggest multiplying the machine enclosure volume by a factor of 2-6 depending on the mist level, with a factor of 2 suitable for large machines of 1000 cubic feet and above.
Condition | Multiplier (X) | Formula |
Light Mist | 1 to 2 | L x W x H x Multiplier = Required CFM |
Moderate Mist | 3 to 4 | L x W x H x Multiplier = Required CFM |
Heavy Mist / Smoke | 4 to 6 | L x W x H x Multiplier = Required CFM |
Example: On a lathe with high-pressure coolant and an internal dimension of 5ft high X 6ft deep X 10ft long, the machine enclosure is 300 cubic feet—the calculation suggests an airflow requirement of approximately 900 CFM, when multiplied by a factor of 3.
Play Now
