Flat rate shipping applied at checkout for domestic orders. If actual rate varies, the final order amount will be adjusted.
For international orders, please contact us for a quote before placing an order.
Mist-Fit MF-1950 Mist Collector
Discover the Mist-Fit 1950: a high-performance, compact mist collector that leverages advanced fiber bed filtration technology for unmatched air purification. Offered at a competitive price, it's the ideal solution for managing high-pressure coolant and oil applications, ensuring fluids are efficiently returned to the CNC machine. Its 25" x 25" design allows for seamless machine integration, enhancing your factory's environment by eliminating mist, smoke, and fine particles. The system's modular build provides flexibility to incorporate additional features as needed.
Country of Origin: Canada
Tech Specs
- Coolant Filtration (Standard)
- Oil Filtration (Optional)
- Air Flow: 1900-2000 cfm
- Machine Tool Enclosure: Up to 2000 ft³
- Motor: 3 hp
- Voltage (Amps):
- 230/3/60 (6)
- 460/3/60 (3.3)
- Temperature (max) pH Limits: 125°F / 50°C, 5.8-9.8
- Weight: 270 lbs / 324 lbs with HEPA filter
- Dimensions: 25" x 25"
- Height:
- 36" base unit
- 44" with 95% HEPA filter
- 48" with 99.9% HEPA filter
- Inlet Connection: 12" ø
- Sound: 72 dB(A)
- Optional 4th Stage Filters:
- HEPA filter 95% @ 0.3 μm
- HEPA filter 99.9% @ 0.3 μm
Separation Stages
Multi-stage separation process effectively eliminates a wide range of airborne contaminants, ensuring not only the longevity and efficiency of machinery but also promoting a healthier workplace environment. By reducing exposure to harmful particulates, it enhances air quality and safety for all workspace occupants.
The innovative 1st stage Mechanical Element separates up to 90% of the oil mist and swarf, with smooth metal surfaces for quick fluid drainage back to the sump.
The 2nd stage Demister Element supports the 1st stage to ensure up to 95% of the mist and swarf are removed with washable filters.
The 3rd stage Fiber Bed mist filter is depth loading and captures small mist particles. With a filter rating of MERV 15, it can be used without a HEPA filter on most applications, with a typical life of 1-3 years.
HEPA Filter captures sub-micron mist, smoke, and bacteria. Efficiency is 95% @ 0.3 μm as standard, and optional 99.9% @ 0.3 μm, with a typical life of 2-4 years.
Pre-Filter Box is recommended for oil and heavy mist, extending filter life, particularly for Swiss screw machines.
Installs Quickly
Easy to Use
Clear the Air
Revolution is in the Air
Why Choose AEROEX?
Premium Filtration
Affordable & Efficient
Health & Safety
Environmental Excellence
Custom Solutions & Expert Support
MF 550
- Air Flow: 500-600 cfm
- Max Enclosure: 250ft
- Motor: 0.75hp
- Max Temp: 125°F (50°C)
- pH Limits: 5.8-9.8
- Weight: 65lbs (HEPA +10lbs)
- Dimensions: 15" x 15" x 26"
- Inlet Connection: 6" ø
- Sound Level: 66 dB(A)
MF 560
- Motor: 0.75hp
- Weight: 96lbs (HEPA +26lbs)
- Dimensions: 20" x 20" x 28"
MF 1050
- Air Flow: 900-1100 cfm
- Max Enclosure: 450ft
- Motor: 1.5hp
- Weight: 98lbs (HEPA +26lbs)
- Inlet Connection: 8" ø
- Sound Level: 68 dB(A)
MF 1950
- Max Enclosure: 2000ft
- Motor: 3 hp
- Weight: 270lbs (HEPA +54lbs)
- Dimensions: 25" x 25" x 36"
- Sound Level: 72 dB(A)
Machine Tool Enclosure Sizing Guide
When determining the sizing of mist collectors, several factors come into play. As a rule of thumb, we suggest multiplying the machine enclosure volume by a factor of 2-6 depending on the mist level, with a factor of 2 suitable for large machines of 1000 cubic feet and above.
Condition | Multiplier (X) | Formula |
Light Mist | 1 to 2 | L x W x H x Multiplier = Required CFM |
Moderate Mist | 3 to 4 | L x W x H x Multiplier = Required CFM |
Heavy Mist / Smoke | 4 to 6 | L x W x H x Multiplier = Required CFM |
Example: On a lathe with high-pressure coolant and an internal dimension of 5ft high X 6ft deep X 10ft long, the machine enclosure is 300 cubic feet—the calculation suggests an airflow requirement of approximately 900 CFM, when multiplied by a factor of 3.
