MACHINIST&
MACHINIST&
MACHINIST&
MACHINIST&
MACHINIST&
TYROLIT
34608787
MACHINIST'S STONE | 100mm X 40mm | Grit C120/C320V
Regular price $99.95 Sale price $94.95
Size
NOTE: FREE SHIPPING now available on domestic orders. This item ship 1-2 weeks from date of purchase.
TYROLIT X TITANS of CNC means unparalleled quality!
Product Details
  • The Tyrolit Machinist's Stone is precision ground to an optimal flatness profile.
  • Built with a two-layer construction process: One layer contains a relatively rough silicon carbide grit with 120 mesh grit dimension to guarantee a certain material removal and the opposite layer contains a fine silicon carbide grit with 320 mesh grit size to ensure a smooth surface finish.
  • Both layers are made with a medium-hard vitrified bond system to achieve a free cutting behavior and at the same time keep the plane surface the machinist desires for a long time.
  • Apply the stone to the surface with coolant or lubricant to achieve the best result.
  • Unit of Tool:Metric
  • Form: 90KR
  • Grit: 120/320
  • Dimensions: 100mm x 40mm
Care Instructions
  • Store the stone on safe, flat surface to maintain its edge.
  • Before first use soak the stone with coolant (water or emulsion).
  • To remove rust, dust, and chips work with the coarse part of the stone (C120)
  • To achieve a perfect surface finish use the fine part at the end.
  • Clean the stone with high-pressure water spray or air after every use.
  • IMPORTANT: Use the entire surface when stoning your work envelope. Avoid only using the edges.
Country of Origin: Austria
Stocked: United States of America.
Since 1919, Tyrolit's innovative tools have made an important contribution to the technological development in many industries. TYROLIT offers tailored grinding solutions for various applications, as well as a comprehensive assortment of standard tools for customers all over the world.
With roots in the heart of the Austrian Alps, TYROLIT combines the strengths of family values with a global vision and over 100 years of individual corporate and technological experience.
  • Orders are processed Monday-Friday and in the order they are received.
  • Orders received after 5:00PM CST will be processed the next business day.
  • Orders are sent via UPS Ground, unless otherwise specified. Shipping times vary by Brand.
    • AMROK: 2-3 weeks
    • Depureco: 2-3 weeks
    • Kennametal: 1-3 days
    • Haimer: 3-5 days
    • LNS: 3-5 days
    • Mitee-Bite: 3-5 days
    • Mitutoyo: 7-14 days
    • Schunk: 3-5 days
    • Tyrolit: 6-8 days
  • Once your order has shipped, you will receive a confirmation email with tracking information.
  • Orders placed outside of the United States may be subject to import and/or brokerage fees upon receipt of package. Check with your Package Carrier and Government for more information.
  • Due to the global Pandemic and its effects on the supply chain, there may be unforeseen delays in some shipments.
RETURNS / REFUNDS / EXCHANGES
You may also like
