SKU: PWS-8110
TOOLEX 8" Single Station Vise | PWS-8110
New Product!
The PWS-8110 sets the standard for quality. Featuring the largest opening in its class of eleven inches and a more robust main screw that can handle higher torque loads and transmit higher clamping pressure. An angled slide and locking jaw design to prevent lifting of the moveable jaw, and the four bolt design on the stationary jaw reduces deflection by 25%.
Features
  • Powder coated paint resists flaking and peeling
  • 80,000psi ductile iron body with increased nickel content for improved corrosion resistance
  • Hardened vise bed and jaw plates
  • Sealed and lubricated needle roller thrust bearing for maximum life and minimum torque
  • Up to 12,000lbs. (53,379N) of clamping force
  • Repeatability within .001" (0.025mm)
  • Outside rails of body are machined within 0.0005" (.013mm) square to jaw
  • Bed height matched to size 3.310" +/- 0.0005" (84.07mm +/- .013mm)
  • Footprint and distance from the keyway to stationary jaw meets industry standard
Specifications
Type Single Station
Style Machinable Jaws
Clamping Pressure 12,000 lb
Jaw Opening 11.000 in
Jaw Width 8.000 in
Total Length 24.470 in
Total Width 11.500 in
Total Height 5.51 in
Material Ductile Iron
Weight 175 lb
Country of Origin: Taiwan (Subject to Change)
Revolution is in the Air
Why Choose TE-CO?
Which Vise is Right for Your Machine Tool?
PWS-4600
  • Type: Single Station
  • Style: Machinable Jaws
  • Clamping Pressure: 7,000 lb
  • Jaw Opening: 6.000 in
  • Jaw Width: 4.000 in
  • Total Length: 14.22 in
  • Total Width: 6.30 in
  • Total Height: 3.63 in
  • Material: Ductile Iron
  • Weight: 33 lb
PWS-6900
  • Clamping Pressure: 8,200 lb
  • Jaw Opening: 9.000 in
  • Jaw Width: 6.000 in
  • Total Length: 19.376 in
  • Total Width: 8.770 in
  • Total Height: 4.625 in
  • Weight: 81.00 lb
PWS-8100
  • Clamping Pressure: 12,000 lb
  • Jaw Opening: 11.000 in
  • Jaw Width: 8.000 in
  • Total Length: 24.470 in
  • Total Width: 11.500 in
  • Total Height: 5.51 in
  • Weight: 175 lb
As Seen in Hit Reality TV Series TITAN: AMERICAN BUILT
TITAN'S FIRST VISE
