SKU: PWS-4600
TOOLEX 4" Standard Quality Vise | PWS-4600
New Product!
The PWS-4600 sets the standard for quality.
Features
  • Powder coated paint resists flaking and peeling
  • 80,000psi ductile iron body with increased nickel content for improved corrosion resistance
  • Hardened vise bed and jaw plates
  • Sealed and lubricated needle roller thrust bearing for maximum life and minimum torque
  • Up to 7,000lbs. of clamping force
  • Repeatability within .001" (0.025mm)
  • Outside rails of body are machined within 0.0005" (.013mm) square to jaw
  • Bed height matched to size 2.250" +/- 0.0005"
  • Footprint and distance from the keyway to stationary jaw meets industry standard
Specifications
Type Single Station
Style Machinable Jaws
Clamping Pressure 7,000 lb
Jaw Opening 6.000 in
Jaw Width 4.000 in
Total Length 14.22 in
Total Width 6.30 in
Total Height 3.63 in
Material Ductile Iron
Weight 33 lb
Country of Origin: Taiwan (Subject to Change)
Revolution is in the Air
Why Choose TE-CO?
Which Vise is Right for Your Machine Tool?
PWS-4600
  • Type: Single Station
  • Style: Machinable Jaws
  • Clamping Pressure: 7,000 lb
  • Jaw Opening: 6.000 in
  • Jaw Width: 4.000 in
  • Total Length: 14.22 in
  • Total Width: 6.30 in
  • Total Height: 3.63 in
  • Material: Ductile Iron
  • Weight: 33 lb
PWS-6900
  • Clamping Pressure: 8,200 lb
  • Jaw Opening: 9.000 in
  • Jaw Width: 6.000 in
  • Total Length: 19.376 in
  • Total Width: 8.770 in
  • Total Height: 4.625 in
  • Weight: 81.00 lb
PWS-8100
  • Clamping Pressure: 12,000 lb
  • Jaw Opening: 11.000 in
  • Jaw Width: 8.000 in
  • Total Length: 24.470 in
  • Total Width: 11.500 in
  • Total Height: 5.51 in
  • Weight: 175 lb
As Seen in Hit Reality TV Series TITAN: AMERICAN BUILT
TITAN'S FIRST VISE
