Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
LH-600 Linear Height Gage
Product Benefits
- Intuitive operation and outstanding ease of use
- Best-in-class accuracy of ± (1.1+0.6L/600) μm
- Easy to operate using keypad and touch screen navigation
- Conduct various measurements: 2D measurement and perpendicularity measurement with just one tool (optional probes available)
- Enhanced data output functions make it easier to manage measurement data
- Measuring Range (Metric): 0 to 977 mm (600 mm)
- Measuring Range (Inch): 0 to 38 in (24 in)
- Resolution (Metric): 0.0001/ 0.001/ 0.01/ 0.1 mm (selectable)
- Resolution (Inch): 0.000001/ 0.00001/ 0.0001/ 0.001 in (selectable)
- Indication Accuracy: ± (1.1 + 0.6L / 600) μm [L = Measured length (mm)]
- Repeatability:
- Plane: 0.4 μm (2 σ)
- Hole: 0.9 μm (2 σ)
- Perpendicularity (Forward and Backward): 5 µm (After Compensation)
- Straightness (Forward and Backward): 4 µm (Mechanical Accuracy)
- Driving Method (Speed): Motor-Driven (5, 10, 15, 20, 25, 30, 40 mm/s: 7 steps) / Manual
- Scale Unit: Photoelectric Incremental Encoder STVC-20Z
- Measuring Force: 1 N (Automatic Constant-Force Function)
- Main Unit Moving Mode: Full-Floating (Moving) / Semi-Floating (Measuring) Air Bearing (Built-in Compressor)
- Display Unit: 8.4 in Touch-Screen, LCD
- Adjustment of Display Unit:
- Stepless tilt adjustment: 0 to 40°
- Stepless swivel adjustment: -30 to 180°
- Preventive Maintenance: Scale Status Notification; Calibration Schedule Notification
- Probe Diameter Compensation:
- Semi-automatic compensation using the probe diameter calibration block (standard accessory)
- Compensation by inputting the probe diameter
- Power Supply: AC Adapter 100-240V±10%; 50/60Hz/ Battery (NiMH)
- Battery Operation Time: Battery Powered (Standard): 4 Hours; Powered by 2 Batteries: 8 Hours
- Battery Charging Time: Approx. 3.5 Hours (Can be Used While Charging)
- Dimensions (W×D×H): 238 (W) × 492 (D) × 996 (H) mm
- Mass: 26.1 kg / 26.6 kg
- Operating Temperature / Humidity Ranges: 5 to 40° C / 20 to 80% RH (non-condensing)
- Data Output: Digimatic d2/S1 (Bi-Directional Communication)
Standard Accessories
- Stepped Probe, Ball-Diameter Compensation Block (with Cover and Base), Auxiliary Weight (2 pcs. Pre-mounted), Battery Pack (1 pc), AC Adapter, Clear Cover, Conveying Handle, Cap, Hex Wrench, Manual Set, Inspection Certificate, Touch Pen, Protective Sheet, Phillips Screwdriver
Country of Origin: Japan
Save BIG when you BUNDLE.
Boost your shop's accuracy and quality with our tooling kits. When your reputation is on the line, you need reliable inspection gear to deliver excellence every project.
