5665804
ZDET SERIES Carbide Inserts for 5720 ALUMINUM INDEXABLE MILLS
#CR016116M540Honed
PLEASE NOTE: Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
Keep On Cutting!- Solid carbide provides better rigidity than high-speed steel
- Honed edge for roughing applications
- Apply under unstable and/or high rotation applications (³24000 rpm spindle speed)
NOTE: Inserts will be delivered with two screws. Because of heavy force to the screw, it is important to change the screw when changing the insert.
Materials- Non-Ferrous Materials, Cast Iron
- Quantity: 5 Inserts
- Series: 5720VZ16
- Insert Style: ZDET
- Insert Size: 16M540
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Honed
- Corner Radius: 0.161"
- Insert Length: 0.906"
- Insert Width: 0.443"
- Insert Height: 0.197"
- Insert Geometry: ER-721
#CR010216M525Honed
- Series: 5720VZ16
- Insert Size: 16M525
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Honed
- Corner Radius: 0.102"
#CR008316M520Sharp
- Sharp edge for finishing applications
- Series: 5720VZ16
- Insert Size: 16M520
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.083"
- Insert Geometry: FR-721
#CR013116M532Sharp
- Series: 5720VZ16
- Insert Size: 16M532
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.131"
#CR024416M560Sharp
- Series: 5720VZ16
- Insert Size: 16M560
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.244"
#CR004916M512Sharp
- Series: 5720VZ16
- Insert Size: 16M512
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.049"
#CR001316M5Sharp
- Series: 5720VZ16
- Insert Size: 16M5
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.013"
- Insert Length: 0.902"
#CR003216M508Sharp
- Compatible with Shell Mill in the Academy Tool Kit
- Series: 5720VZ16
- Insert Size: 16M508
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.032"
#CR016116M540Sharp
- Series: 5720VZ16
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
#CR006616M516Sharp
- Series: 5720VZ16
- Insert Size: 16M516
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.066"
#CR012316M530Sharp
- Series: 5720VZ16
- Insert Size: 16M530
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.123"
#CR010216M525Sharp
- Series: 5720VZ16
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
#CR001516M504Sharp
- Series: 5720VZ16
- Insert Size: 16M504
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.015"
#CR012316M530Honed
- Series: 5720VZ16
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Honed
#CR020516M550Sharp
- Series: 5720VZ16
- Insert Size: 16M550
- Grade: GH1
- Coating: Uncoated
- Cutting Edges: 2
- Edge Type: Sharp
- Corner Radius: 0.205"
With over 80 years as an industrial technology leader, Kennametal Inc. delivers productivity to customers through materials science, tooling and wear-resistant solutions. Customers across aerospace, earthworks, energy, general engineering and transportation turn to Kennametal to help them manufacture with precision and efficiency.
- Orders are sent via UPS Ground, unless otherwise specified. Shipping times vary by Brand.
- Once your order has shipped, you will receive a confirmation email containing tracking information.
- Due to the global Pandemic and its effects on the supply chain, there may be unforeseen delays in some shipments.
RETURNS / REFUNDS / EXCHANGES
- Please see our detailed information related to this topic at RETURN / REFUND / EXCHANGE Policies
