293-185-30
IP65 QuantuMike Digimatic Outside Micrometer
#34in7621016mm-NoOutput
PLEASE NOTE: Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
Product Detail Specifics to the 3-4" No Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- A patented ratchet thimble mechanism helps ensure repeatability
- A function lock helps prevent error
- Certificate of inspection is provided
- With standard bar, except 0-25mm/0-1" model
- Supplied in fitted plastic case
- Dust/Water protection level: IP65
- Accuracy: Refer to the list of specifications
- Resolution: 0.001mm or .00005"/0.001mm
- Flatness:0.3µm/.000012"
- Parallelism: 1µm/.00004" for models up to 50mm/2"
- 2µm/.00008" for models up to 100mm/4"
- Measuring faces: Carbide tipped
- Display: LCD
- Battery: SR44 (1 pc.), 938882
- Battery life: Approx. 1.2 years under normal use
#34in7621016mm-SPCDataOutput
Product Detail Specifics to the 3-4" SPC Data Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- With standard bar, except0-25mm/0-1" model
- Display: LCD
#23in508762mm-NoOutput
Product Detail Specifics to the 2-3" No Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- A function lock helps prevent error IP-65 protection level
- Display: LCD
#23in508762mm-SPCDataOutput
Product Detail Specifics to the 2-3" SPC Data Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- Display: LCD
#12in254508mm-NoOutput
Product Detail Specifics to the 1-2" No Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- Display: LCD
#12in254508mm-SPCDataOutput
Product Detail Specifics to the 1-2" SPC Data Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- Display: LCD
#01in0254mm-NoOutput
Product Detail Specifics to the 0-1" No Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- Display: LCD
#01in0254mm-SPCDataOutput
Product Detail Specifics to the 0-1" SPC Data Output Variant- Faster measurement with 2mm per rev. instead of the standard 0.5
- Display: LCD
Mitutoyo's philosophy has been "to contribute to the wellbeing of society through precision measurement technologies." From developing optimum analysis environments, to process improvement for on-site applications of Mitutoyo equipment, and on to the realization of factories that do not sleep through the utilization of measurement data—the foundations of manufacturing run deep and the possibilities run deeper.
- Free shipping on orders of $250 or more applies to Haimer tooling, Kennametal tooling, Mitutoyo tooling, and TITANS of CNC merchandise only. Offer not valid on AMROK, LNS, Mitee-Bite, Schunk, or Tyrolit products.
- Some promotional items not eligible for free shipping.
- Orders are sent via UPS Ground, unless otherwise specified. Shipping times vary by Brand.
- Once your order has shipped, you will receive a confirmation email containing tracking information.
- Due to the global Pandemic and its effects on the supply chain, there may be unforeseen delays in some shipments.
RETURNS / REFUNDS / EXCHANGES
- Please see our detailed information related to this topic at RETURN / REFUND / EXCHANGE Policies
