LNS
F311032000
FOX WS2 Oil & Coolant Mist Collector
Regular price $3,675.00 Sale price $3,375.00
Model
Product Details
  • Elimination of oil/coolant mist and smoke in metal cutting applications
  • Ensures a clean, safe work environment while reducing absenteeism and HVAC costs
  • Easy to use
  • Removes up to 99.95% of the cutting mist
#330
  • Air Flow (cfm): 330
  • Static Pressure Inches: 3.57
  • Motor (hp): 0.6
  • Amps at 230V: 2
  • Weight (lbs): 77
  • Sound Level (dBA): 65
  • Filtration Efficiency: up to 99.95% MPPS(EN1822)
  • Suction Inlet Diameter: 125 mm (5")
#700
  • Air Flow (cfm): 665
  • Static Pressure Inches: 5.70
  • Motor (hp): 1.2
  • Amps at 230V: 2.9
  • Weight (lbs): 121
  • Sound Level (dBA): 71
  • Suction Inlet Diameter: 150 mm(6")
#1020
  • Air Flow (cfm): 1012
  • Static Pressure Inches: 7.23
  • Motor (hp): 2.4
  • Amps at 230V: 5.7
  • Weight (lbs): 165
  • Sound Level (dBA): 73
  • Suction Inlet Diameter: 200 mm(8")
#1250
  • Air Flow (cfm): 1248
  • Static Pressure Inches: 9.23
  • Motor (hp): 3.5
  • Amps at 230V: 8.3
  • Weight (lbs): 187
  • Sound Level (dBA): 75
For more than 45 years, LNS products have improved CNC machine performance worldwide. In the field of air filtration, LNS applications experts match oil/coolant mist collectors to each user's specific needs. LNS Fox WS2 and WM2 multi-stage oil/coolant mist collectors are suitable for all machine types and processes using water-soluble, synthetic, or neat oil coolants, and are available with airflow of 168 to 2350 cfm. HE 1000 electrostatic oil mist collectors are designed specifically for wet machining operations using straight oil. All LNS oil/coolant mist collectors exceed OSHA and NIOSH industrial standards. To eliminate 99% of fine aerosol mist when using air guns to clean oily parts between operations, LNS offers the Fox SC2 330 spray cabin.
In addition to industry-leading air filtration systems, LNS designs, manufactures and supports manual and automatic bar feeders for bar stock diameters from .039" - 4-3/4"; chip conveyors for virtually every chip size, shape, and material; ChipBLASTER coolant delivery and cyclonic filtration systems; and work support devices. Over 700 LNS specialists worldwide stand behind every product we sell.
  • Orders are processed Monday-Friday and in the order they are received.
  • Orders received after 5:00PM CST will be processed the next business day.
  • Orders are sent via UPS Ground, unless otherwise specified. Shipping times vary by Brand.
    • AMROK: 2-3 weeks
    • Depureco: 2-3 weeks
    • Kennametal: 1-3 days
    • Haimer: 3-5 days
    • LNS: 3-5 days
    • Mitee-Bite: 3-5 days
    • Mitutoyo: 7-14 days
    • Schunk: 3-5 days
    • Tyrolit: 6-8 days
  • Once your order has shipped, you will receive a confirmation email with tracking information.
  • Orders placed outside of the United States may be subject to import and/or brokerage fees upon receipt of package. Check with your Package Carrier and Government for more information.
  • Due to the global Pandemic and its effects on the supply chain, there may be unforeseen delays in some shipments.
RETURNS / REFUNDS / EXCHANGES
WHY CHOOSE US?
The Industry Leader
With experience running an elite aerospace CNC shop, we know what it takes to deliver at the highest levels. From serving clients to now lifting up our industry, our team is a recognized leader through our online Academies and communities.
Trusted Experience
Our engineers, designers, modelers, machine operators, finishing, and fulfillment team members have decades of combined experience dealing with the unique pressure of crafting the most difficult high-tolerance parts.
Support Free Education
We’re proud to be lifting up students, educators, and the manufacturing workforce. Your purchase supports TITANS of CNC: Academy, the world's largest free online CAD/CAM and CNC Academy, used in over 170 countries.
FEATURED PRODUCT HIGHLIGHTS
Best Practices with LNS
Every product we feature has been rigorously tested and used by our team. Learn from our experience and get the most out of your LNS purchase.
Titans of CNC: Academy
THE LARGEST FREE CAD/CAM AND CNC ACADEMY
See why 100,000+ students, educators, and machinists have turned to our FREE online academies.
Let's RISE to GREATNESS together!
Learn More
You may also like
