FOX SC2 330 Spray Cabin
LNS
F311238000
Regular price $1,950.00
Product Details
LNS Fox SC2 330 Spray Cabin is an ideal solution to eliminate fine aerosol mist produced by air guns. Such as when blowing off oily parts prior to their next operation, inspection or packaging. Further, this unit has a high-efficiency filtration system that eliminates more than 99% of contaminants.  A single-phase fan motor draws air at 344 CFM through a washable pre-filter and then through the long-life, easily accessible main filter.
  • Input Voltage (AC): 110V 1 Ph 60Hz
  • Voltage Range (AC): 108-132V 60Hz
  • Current: 1.7 A
  • Power: 220 W [0.3 Hp]
  • Size: L 19 x W 16 x H 45 inches
  • Weight: 132 lbs
  • Control: Auto, On, Off selector switch with illuminated running light
  • Noise Level: 58 dB(A)
  • Air Flow: 344 CFM
  • Air Velocity: 9.5 f/s
  • Pre Filter: Washable metallic pre-filter
  • Main Filter: (F9) Media main filter (same as WS2 330 mist collector)
  • Coolant Collection: Removable draw with sight glass / level
For more than 45 years, LNS products have improved CNC machine performance worldwide. In the field of air filtration, LNS applications experts match oil/coolant mist collectors to each user's specific needs. LNS Fox WS2 and WM2 multi-stage oil/coolant mist collectors are suitable for all machine types and processes using water-soluble, synthetic, or neat oil coolants, and are available with airflow of 168 to 2350 cfm. HE 1000 electrostatic oil mist collectors are designed specifically for wet machining operations using straight oil. All LNS oil/coolant mist collectors exceed OSHA and NIOSH industrial standards. To eliminate 99% of fine aerosol mist when using air guns to clean oily parts between operations, LNS offers the Fox SC2 330 spray cabin.
In addition to industry-leading air filtration systems, LNS designs, manufactures and supports manual and automatic bar feeders for bar stock diameters from .039" - 4-3/4"; chip conveyors for virtually every chip size, shape, and material; ChipBLASTER coolant delivery and cyclonic filtration systems; and work support devices. Over 700 LNS specialists worldwide stand behind every product we sell.
  • Orders are sent via UPS Ground, unless otherwise specified. Due to the global Pandemic and its effects on the procurement supply chain there may be unforeseen delays in some shipments.
  • Once your order has shipped you will receive a shipping confirmation email containing tracking information.
RETURNS / REFUNDS / EXCHANGES
WHY CHOOSE US?
The Industry Leader
With experience running an elite aerospace CNC shop, we know what it takes to deliver at the highest levels. From serving clients to now lifting up our industry, our team is a recognized leader through our online Academies and communities.
Trusted Experience
Our engineers, designers, modelers, machine operators, finishing, and fulfillment team members have decades of combined experience dealing with the unique pressure of crafting the most difficult high-tolerance parts.
Supporting Free Education
We’re proud to be lifting up students, educators, and the manufacturing workforce. Your purchase supports TITANS of CNC: Academy, the world's largest free online CAD/CAM and CNC Academy, used in over 170 countries.
FEATURED PRODUCT HIGHLIGHTS
Best Practices with LNS
Every product we feature has been rigorously tested and used by our team. Learn from our experience and get the most out of your LNS purchase.
Titans of CNC: Academy
THE LARGEST FREE CAD/CAM AND CNC ACADEMY
See why 100,000+ students, educators, and machinists have turned to our FREE online academies.
Let's RISE to GREATNESS together!
Learn More
You may also like
