F311239000
FOX HE 1000 Electrostatic Oil Mist Collector
Product Details
- Filtration efficiency
- Dual door access
- Safety Features
- Maintenance efficiency
- Optional: HEPA kit and discharge port
- Model: HE 1000
- Airflow (cfm): 882
- Motor (hp): 0.5
- Amps at 220V: 2.3
- Weight (lbs): 117
- Weight of Cell (lbs): 17
- Sound Level (dB(A)): 67
- Suction Inlet Diameter (mm |in): 150 (6)
For more than 45 years, LNS products have improved CNC machine performance worldwide. In the field of air filtration, LNS applications experts match oil/coolant mist collectors to each user's specific needs. LNS Fox WS2 and WM2 multi-stage oil/coolant mist collectors are suitable for all machine types and processes using water-soluble, synthetic, or neat oil coolants, and are available with airflow of 168 to 2350 cfm. HE 1000 electrostatic oil mist collectors are designed specifically for wet machining operations using straight oil. All LNS oil/coolant mist collectors exceed OSHA and NIOSH industrial standards. To eliminate 99% of fine aerosol mist when using air guns to clean oily parts between operations, LNS offers the Fox SC2 330 spray cabin.
In addition to industry-leading air filtration systems, LNS designs, manufactures and supports manual and automatic bar feeders for bar stock diameters from .039" - 4-3/4"; chip conveyors for virtually every chip size, shape, and material; ChipBLASTER coolant delivery and cyclonic filtration systems; and work support devices. Over 700 LNS specialists worldwide stand behind every product we sell.
- Free shipping on orders of $250 or more applies to Haimer tooling, Kennametal tooling, Mitutoyo tooling, and TITANS of CNC merchandise only. Offer not valid on LNS or Schunk products.
- Orders are sent via UPS Ground, unless otherwise specified. Shipping times vary by Brand.
- Once your order has shipped, you will receive a confirmation email containing tracking information.
- Due to the global Pandemic and its effects on the supply chain, there may be unforeseen delays in some shipments.
RETURNS / REFUNDS / EXCHANGES
- Please see our detailed information related to this topic at RETURN / REFUND / EXCHANGE Policies
