HYDRAULIC CHUCK REDUCER SLEEVES | 3/4" - 1 1/4" | Inch with Metric Bores
Regular price $136.84
#34OD3mmID19685
Kennametal® Hydraulic Reduction Sleeves are designed for high-precision clamping of straight cylindrical cutting tool shanks. The self-sealing design enables efficient use of through-coolant cutting tools when the cutting tool shank completely engages the full gripping length of the sleeve.
Designed for Precision, Stability, and Efficiency
  • Accelerated feed rates offer increased productivity
  • Four-wall pocket provides insert stability
  • One-piece design with slot configuration to seal coolant
  • Through coolant standard for improved tool life, hole finish, and chip removal
  • Cutting tool must be cylindrical and have a through hole when using coolant
  • Units Supported: Inch with Metric Bores
  • Adapter Style: Straight Shank
  • Sleeve Series: HC750
  • Shank Outer Diameter: 0.750"
  • Shank Inner Diameter (Inch): 0.1181"
  • Shank Inner Diameter (Metric): 3.000mm
  • Shank Length: 1.9685"
  • Gage Length: 0.1569"
  • Overall Length: 2.126"
  • Through Coolant: Yes
#34OD4mmID19685
  • Shank Inner Diameter (Inch): 0.1575"
  • Shank Inner Diameter (Metric): 4.000mm
#34OD5mmID19685
  • Shank Inner Diameter (Inch): 0.1969"
  • Shank Inner Diameter (Metric): 5.000mm
#34OD6mmID19685
  • Shank Inner Diameter (Inch): 0.2362"
  • Shank Inner Diameter (Metric): 6.000mm
#34OD8mmID19685
  • Shank Inner Diameter (Inch): 0.315"
  • Shank Inner Diameter (Metric): 8.000mm
#34OD10mmID19685
  • Shank Inner Diameter (Inch): 0.3937"
  • Shank Inner Diameter (Metric): 10.000mm
#34OD12mmID19685
  • Shank Inner Diameter (Inch): 0.4724"
  • Shank Inner Diameter (Metric): 12.000mm
#34OD14mmID19685
  • Shank Inner Diameter (Inch): 0.5512"
  • Shank Inner Diameter (Metric): 14.000mm
#34OD16mmID19685
  • Shank Inner Diameter (Inch): 0.6299"
  • Shank Inner Diameter (Metric): 16.000mm
#114OD18mmID23622
  • Sleeve Series: HC1250
  • Shank Outer Diameter: 1.250"
  • Shank Inner Diameter (Inch): 0.7087"
  • Shank Inner Diameter (Metric): 18.000mm
  • Shank Length: 2.3622"
  • Gage Length: 0.1575"
  • Overall Length: 2.5197"
#114OD20mmID23622
  • Shank Inner Diameter (Inch): 0.7874"
  • Shank Inner Diameter (Metric): 20.000mm
#114OD25mmID23622
  • Shank Inner Diameter (Inch): 0.9843"
  • Shank Inner Diameter (Metric): 25.000mm
With over 80 years as an industrial technology leader, Kennametal Inc. delivers productivity to customers through materials science, tooling and wear-resistant solutions. Customers across aerospace, earthworks, energy, general engineering and transportation turn to Kennametal to help them manufacture with precision and efficiency.
  • Orders are sent via UPS Ground, unless otherwise specified. Due to the global Pandemic and its effects on the procurement supply chain there may be unforeseen delays in some shipments.
  • Once your order has shipped you will receive a shipping confirmation email containing tracking information.
RETURNS / REFUNDS / EXCHANGES
Why choose us?
The Industry Leader
With experience running an elite aerospace CNC shop, we know what it takes to deliver at the highest levels. From serving clients to now lifting up our industry, our team is a recognized leader through our online Academies and communities.
Trusted Experience
Our engineers, designers, modelers, machine operators, finishing, and fulfillment team members have decades of combined experience dealing with the unique pressure of crafting the most difficult high-tolerance parts.
Supporting Free Education
We’re proud to be lifting up students, educators, and the manufacturing workforce. Your purchase supports TITANS of CNC: Academy, the world's largest FREE online CAD/CAM and CNC Academy, used in over 170 countries.
Featured product highlights
Best Practices With Haimer
Every product we feature has been rigorously tested and used by our team. Learn from our experience and get the most out of your Haimer purchase.
The Largest Free CAD/CAM/CNC Academy
See why 100,000+ students, educators, and machinists have turned to our family of FREE online academies.
Let's RISE to GREATNESS together!
Learn More
