SUPPORT FREE EDUCATION
SKU: 4149678
GOdrill (THROUGH COOLANT) | 8.733mm / .3438" / 8xD | SOLID CARBIDE DRILL | 4149678
Sale price$190.69 Regular price$208.56
"The GOdrill is standard tooling in my shop and it should be in yours, too. We efficiently drill Plastic, Aluminum, Steel, Titanium, Inconel, and Monel with the same drill."
  • Solid Carbide drilling for diameter 1-20mm (0.0394"-0.7874") for 3-8 x D drilling capability
  • Reduced friction and heat with Marginless design
  • Through-coolant available down to 1mm (0.0394")
  • TiN top layer serves as wear indicator
  • Steel, Stainless Steel, Cast Iron, High-Temp Alloys; Non-Ferrous Materials, Hardened Materials
  • Adapter Style: Straight-Cylindrical
  • Coating: TiN
  • Grade: KC7325
  • Through Coolant: Yes
  • Flute Type: Spiral
  • Number of Flutes: 2
  • Flute x Diameter Ratio: 7
  • Flute Length (Inch): 3.1496"
  • Flute Length (Metric): 80.000mm
  • Overall Length (Inch): 4.8031"
  • Overall Length (Metric): 122.000mm
  • Shank Diameter (Inch): 0.3937"
  • Shank Diameter (Metric): 10.000mm
  • Shank Length (Inch): 1.5748"
  • Shank Length (Metric): 40.000mm
  • Maximum Drill Depth (Inch): 2.6772"
  • Maximum Drill Depth (Metric): 68.000mm
  • Drill Point Length (Inch): 0.0583"
  • Drill Point Length (Metric): 1.480mm
  • Drill Point Angle): 140°
