F311238000
FOX SC2 Spray Cabins
Product Details
The LNS Fox SC2 Spray Cabin is an ideal solution to eliminate fine aerosol mist produced by air guns. When you're blowing off oily parts, that mist becomes part of your environment. These Spray Cabins have a high-efficiency filtration system that eliminates more than 99% of contaminants. A single-phase fan motor draws air at high CFM through a washable pre-filter and then through the long-life, easily accessible main filter. Breathe easier with the LNS Fox SC2 Spray Cabin!
#SC2700
- Nominal Air Flow (cfm): 530
- Motor (hp):0.36
- Current Draw (A): 2.4
- Voltage/Phase/Frequency (V/Hz): 120 / 1 / 60
- Sound Level (db(A)): 62
- Weight: 204lbs
- Dimensions (LxWxH): 23"x21"x49"
- Control: Auto, On, Off selector switch with illuminated running light
- Pre Filter: Washable metallic pre-filter
- Main Filter: (F9) Media main filter (same as WS2 330 mist collector)
- Coolant Collection: Removable draw with sight glass / level
#SC2330
- Nominal Air Flow (cfm): 344
- Motor (hp):0.22
- Current Draw (A): 1.7
- Sound Level (db(A)): 58
- Weight: 132lbs
- Dimensions (LxWxH): 19"x17"x45"
For more than 45 years, LNS products have improved CNC machine performance worldwide. In the field of air filtration, LNS applications experts match oil/coolant mist collectors to each user's specific needs. LNS Fox WS2 and WM2 multi-stage oil/coolant mist collectors are suitable for all machine types and processes using water-soluble, synthetic, or neat oil coolants, and are available with airflow of 168 to 2350 cfm. HE 1000 electrostatic oil mist collectors are designed specifically for wet machining operations using straight oil. All LNS oil/coolant mist collectors exceed OSHA and NIOSH industrial standards. To eliminate 99% of fine aerosol mist when using air guns to clean oily parts between operations, LNS offers the Fox SC2 330 spray cabin.
In addition to industry-leading air filtration systems, LNS designs, manufactures and supports manual and automatic bar feeders for bar stock diameters from .039" - 4-3/4"; chip conveyors for virtually every chip size, shape, and material; ChipBLASTER coolant delivery and cyclonic filtration systems; and work support devices. Over 700 LNS specialists worldwide stand behind every product we sell.
- Free shipping on orders of $250 or more applies to Haimer tooling, Kennametal tooling, Mitutoyo tooling, and TITANS of CNC merchandise only. Offer not valid on LNS or Schunk products.
- Orders are sent via UPS Ground, unless otherwise specified. Shipping times vary by Brand.
- Once your order has shipped, you will receive a confirmation email containing tracking information.
- Due to the global Pandemic and its effects on the supply chain, there may be unforeseen delays in some shipments.
RETURNS / REFUNDS / EXCHANGES
- Please see our detailed information related to this topic at RETURN / REFUND / EXCHANGE Policies
